AP-134 Lightning Protection
I am investigating the following setup:
AP-134 --> Feeder Cable --> Lightning Protector --> Antenna
Would the LAR-1 support the diplex output from the AP and provide surge protection? I have also seen the LAR-24 which supports only the 2.4GHz band. Would I need one surge protector per band or can the LAR-1 do it all for me?
Thank you
Contributor II
Re: AP-134 Lightning Protection
The AP-LAR-1 supports a 2.0-6.0 GHz frequency range and can be used for 2.4-2.5 GHz or 5 GHz deployments.
Thank you
