Trusted Contributor I
AP-134 with AP-ANT-16 provision settings
to which values do i set the antenna gain when provision such a combination? the spec sheet is giving me 3.9 and 4.7, but i can only enter integer values, ie 3,4 or 5.
Aruba
Re: AP-134 with AP-ANT-16 provision settings
Just round the numbers. I believe you can enter numbers in 0.5dB steps, so I would suggest 4.0dBi and 4.5dBi
/Onno
/Onno
