Contributor II
AP 135 LED state
Hi there.
We are used to deploy AP135 but for the first time today we got 2 amber LED for 5 and 2.4 ghz
I am a but confused regarding the explenation on the user manual
Could someone give me a little hint on
Amber 5 GHz radio enabled in WLAN mode
5 GHz radio enabled in 11n mode
I can understand the 11 n mode but what about the WLAN mode.. it is not so clear to me.
Thanks.
Re: AP 135 LED state
Are these APs tied to a Controller ?
If yes make sure that you have a Virtual-AP Assigned under the AP-Group .
Under the SSID Profile > HT profile verify that HT is enabled
Do you have AP licenses on the controller installed ?
Under Configuration > AP Installation see if the AP shows up with any flags
Sent from Outlook Mobile
Thank you
Victor Fabian
Lead Mobility Architect
Contributor II
YEs they are tied to a controller.
There is indeed few VAP under the AP group
HT is disabled because we want it that way
and regarding the licensing it is all good (still 100 ish available)
Thank you
It is not clearly worded.  WLAN mode just means that it is not configured as an Air Monitor or Spectrum Monitor.  It is servicing clients.  If it is Amber that means one or more SSIDs have HT disabled.
Colin Joseph
Aruba Customer Engineering
Contributor II
Ok , it makes sense then.
