AP-135 soft gre tunnel without controller
Hi experts,
I have Aruba- ap135.I am using currently at instant mode and trying to do eap-sim authentication without using a controller.I am stuck at gre tunnel configuration which is easy to do with controller.No idea if i am capable to do that in ap135 in cli or gui.I searched but could'nt find something useful. So, is it possible? if yes do you have some sample tunnel configuration.
Thanks in advance
Doruk
Re: AP-135 soft gre tunnel without controller
It is not possible ! you need a controller...
ACMP 6.4 / ACMX #107 / ACCP 6.5
so are you running Instant software on IAP-135?
Instant software does support GRE tunnelling.
