AP-135 starting as AM
Dear all:
We've just installed 15 AP-105 and 5 AP-135.
All 105 start working as AP, but all 135 start as AM
All equipment is forced to use 5 GHz to avoid interfering with the current WLAN to be replaced
Using AOS 6.1.x and changing the default profile to enable-AP worked out, but after moving to last version all 135 stay in AM-mode
As all 135 are on the same floor, no signal is provided there, only AM.
Any help about that ?
thanks
regards,
Nelson
Nelson La Rocca
B4B Corp.
Re: AP-135 starting as AM
nelsonlarocca wrote:
Dear all:
thanks
regards,
Nelson
Two questions:
What is the version of ArubaOS and what regulatory domain are you using?  It is possible that the 135 is not yet enabled for your regulatory domain, for that version of code.
great ! that 's the matter
I switched back to US and it worked out. All AP-135 are seen as AP immediately
thanks a lot
regards,
Nelson
Nelson La Rocca
B4B Corp.
