When configuring an AP-175 or a AP-274 to a Aruba Controller does any of these AP's need to be consoled into first? I know that with the AP-105 for instance, when it is connected to the switch it will power up & automaticly appear on the controller GUI so that it can be configured from the controller by default. Do these 2 AP's work like that or do they have their own dedicated GUI that needs to be turned off first. Do they need to be consoled into & put into controller mode first?
So based of your info the AP's below do NOT need to be configured apart from the controller first correct?
Product description: Aruba AP-175AC Otdr AC Pwr 11n AP Product number: JX776A
Part description: Aruba AP-274 Otdr Dual 3x3:3 802.11ac AP
