AP 175 configuration... bg is not working
   we Install AP 175 with 4 antennas 2005-v and h and 5005-v and h..... and AP 175 is showing up ...we have all APs are in default group and AP 105 is working fine and broadcasting SSID on 2.5 and 5 but AP 175 is not and while checking no bg channels is there..and AP is working as AM.. can any one guide me how ill configure AP 175 that it will work as other AP...
No point to point link just for outdoor connectivity for users.......
thanks
Aruba
Re: AP 175 configuration... bg is not working
If you see the AP as an Air Monitor, the 802.11g radio profile is may be set as such.  Please check the following for the AP Group the AP is In:
RF Management --> 802.11g radio
Check the profile and check what "mode" is set.
am-mode = Air Monitor
ap-mode = AP (hybrid)
AMFX | ACCX | ACDX | ACMX
You can also contact TAC and they can work through the configuration with you.
-cl
Thanks for your support,
It was a regulatory domain issue..... :-)
