Occasional Contributor I
AP-205 Part number validation
We are planning to order three  controller based AP-205 access point and please validate the below part numbers:
1JW164A  Aruba AP-205 802.11n/ac Dual 2x2:2 Radio Integrated Antenna AP3
2JW627APD-3510G-AC 15.4W 802.3af PoE 10/100/1000Base-T Ethernet Midspan Injector3
3JW115APC-AC-BR Brazil AC Power Cord3
4JY705AAP-200-MNT-W3 White Low Profile Box Style Secure Small AP Flat Surface Mount Kit3
Re: AP-205 Part number validation
Yep, looks ok to me.
Cheers
James
Thanks for your reply, Please validate below BOM also
JW164A Aruba AP-205 Dual 2x2:2 802.11ac AP
JW629A PD-9001GR-AC 30W 802.3at PoE+ 10/100/1000 Ethernet Indoor Rated Midspan Injector
JW047A AP-220-MNT-W1W Flat Surface Wall/Ceiling White AP Basic Flat Surface Mount Kit
JW115A PC-AC-BR Brazil AC Power Cord
