Occasional Contributor I
AP 205 boot led keeps blinking
Just got the AP 205 and during boot the led keeps blinking forever and won't boot up.
Tried to hard reset the ap by pressing the reset during switching on. Any help?(:
Re: AP 205 boot led keeps blinking
Are you providing dhcp to that AP?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I'm running a network with a DHCP server from the router. Also got an IAP 205 which is working fine.
So I guess the answer is yes
Do you have a controller? An AP 205 (not an IAP) requires a controller.
I thought the IAP was able to control the AP.. But that's not the case?
That is not the case.
