Regular Contributor I
AP 215 Mount Kit
HI guys,
a very simple question , which mount kit I can use to mount my 215 ap to the ceiling?
AP-220-MNT-W2 or AP-220-MNT-W1?
thanks in advance
best regards
Andrea
Aruba
Re: AP 215 Mount Kit
Check out the ordering guide for the 210 series:  http://www.arubanetworks.com/pdf/products/OG_AP-210Series.pdf
AMFX | ACCX | ACDX | ACMX
Aruba
Either will work with the 215; but they are both wall mount options.  They could be used on ceilings as well.  I've attached the installation guides for the two so you can see the difference.
Thank you =)
Andrea
