AP-220 mount kit uninstall
Does anyone have any experience in uninstalling an AP-115 from a AP-220-MNT-W1 mount kit? Just twisting doesn't seem to be an option, and there's no way to get two tools in to open up the catches whilest twisting the AP. The hardware installation kit for both the AP and mount kit talk about installation, but not about un-installation of the kit to the AP.
Thanks for any insights,
Steven
ACDX #391
Re: AP-220 mount kit uninstall
Usually you just have to twist really hard to the point where you think you're going to break it.
Tim Cappalli | Aruba Security
Counterclockwise twist with some torque ...
