Regular Contributor II
AP-224 Wall mount?
Hi Forum,
I want to mount an AP-224 on an indoor wall. I'm not sure which mount to order, I see on the ordiring guide (screen cap attached) many options but it is not clear to me.
All I need is that ap224 to be mounted on a wall(not in a box).
Re: AP-224 Wall mount?
W1 is a "spider"style that screws into the wall and the AP twists on.
W2 is a secured method where the AP is locked* into a surface mount
(*locked with a hex screw)
Tim Cappalli | Aruba Security
Thank you very very much.
