[AP 225 , AP275] second ethernet Port Questions
Dear All,
can we use the second Ethernet Port of the AP 225 and 275 as an uplink to other  AP , or we can just use it for aggeregation ?
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: [AP 225 , AP275] second ethernet Port Questions
No, you should not daisy chain APs.
Tim
Tim Cappalli | Aruba Security
Hi caplari,
thank you for the feedback,
but please tell me i can't or i should not ?!
Raouf CHAHBOUNE
The second Ethernet port was not designed for that. It was designed for LACP or failover with spanning tree. It is possible this will do what you want but I have not configured this for any customers.
thank you for the replay , yes it was designed for Aggergation with LACP , with that the AP will support up to 2 Gbps uplink wich can handle the traffic (1,3 Gbps +300 Mbps ).
but i need to know if it is possible or not :).
Regards
Raouf CHAHBOUNE
