AP-225 Stuck in AM mode
Have just deployed 8 new AP-225's
Aruba Controller Firmware version 6.3.0.0
All 8 Ap's show up as AM mode on both channels when doing show AP Active and also in GUI yet they are configured according to RF profile as AP mode.
Show AP Active
SNR_HALL02 APPLETV-EBT 10.1.140.175 0 AM 0 AM 225 Aa 13m:52s N/A
RF Profile is the default used for all the other AP's and all AP105 and AP61 correctly show mode as AP-Mode.
Have tried provisioning to different profiles and reboot but same issue.
AP Config shows Mode as correctly as AP.
Show AP Config ap-name SNR_HAll02
Mode ap-mode ap-mode rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
Any ideas - there are no special configs for these AP's that I am aware of.
Cheers
Wally
Super Contributor I
Re: AP-225 Stuck in AM mode
What regulatory domain are you in?
ACDX #419 | ACMP |
You will likely see in the logging that there are no available channels in the regulatory domain or some regulatory domain mismatch.
Please upgrade to a newer ArubaOS release (for example 6.3.1.9) to solve that. Regulatory domain settings for your region may have been missing at the moment of release of 6.3.0.0.
Starting with ArubaOS 6.4, there is a feature (DRT) that allows you to update regulatory information without upgrading the OS.
Long overdue update.
Upgraded the firmware as suspected to 6.3.1.8 and AP's are now working in AP mode.
Many thanks for the advice.
Wally
