AP 225 Transmit power min and max.
I have a 1to 1 enviroment with a ap in every class, I need to know what  my transmit power max and min should be, 70 aps, class by class, what is the default for a 225?
Regular Contributor II
Re: AP 225 Transmit power min and max.
Max transmit power...
  • 2.4-GHz band: +23 dBm
  • 5-GHz bands: +23 dBm
You can get all specification in about 225
http://cloud.arubanetworks.com/products/instant-224-225#specification
HTH
Cheers
SumaN
Awesome thank you this helps.
[https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcTK6wPrDnODdBrTkmThJweFNT84wRKzdYQ78OqvJPxnt9ORqUhr]Dale Nevarez SFPS-Technology Dept.
2516 Cerrillos Road
Santa Fe, NM 87505 505 467-2554 Cell 505 670-5479
[it]
Disclaimer: This message and any attachments are intended for the use of the addresses(s) only and may be confidential and/or legally privileged. If the reader is not the intended recipient, DO NOT READ, notify sender and delete this message. In addition, be aware that any disclosure, copying, distribution or use of the contents of this message is strictly prohibited. The contents of this message, while possibly falling under the exceptions of the Inspection of Public Records ACT [NMSA Chapter 14, Article2] may be subject to inspection by the public.
MVP
If you got one AP per each classroom i would have 12 - 15 dbm or 15 to 18 but no more than that...
It is recommended that you dont use the maximum output power.   This can casuse issues to the client match and the devices not roaming correctly.
Plus remeember that most of the cellphones and devices like that their maximum output power is something like 17dmb or 18...  and if you put 23dbm the AP can see the client but the client  might not  be able to asnwer the ap back properly.
Cheers
Carlos
Alternetworks Corp
