AP-225 power status
Hi Airheads experts!
I know there are a limitations at ap-225 if the the ap get af power (2,4 GHz 1x1, disable secondary ethernet and usb port).
If I turn off 5 GHz radio (disable radio) Can I use 2,4 GHz radio with 3x3 MIMO. Is it possible?
We don't have 5 GHz clients!
I try to disable 5 GHz radio but I don't see any changes.
Super Contributor I
Re: AP-225 power status
The power change on the 220 series is standard regardless of what changes are made. If full at power isn't available via the switch you can always buy an at injector and disable PoE on the switch port.
ACDX #419 | ACMP |
