AP 225 power usage
Hello
I was reading the data sheet i know the AP 225 is poe+
But let say im not using the USB and im just just one port of the AP
I read on the datasheet this
 Worst-case power consumption from the AP (excluding power drawn by an attached USB device):
- In restricted mode (PoE): 13.5W
- In unrestricted mode (PoE): 17W
- In unrestricted mode (DC): 15.5W
Does this mean that the AP 225 will use all his streams 3x3 in 2.4ghz and 5ghz  17 W?  i mean the AP wont go in conservative mode in which  you will see the PWR led going orage which means that its using1×3:1SS mode  ?
Now fallowing that logic
I would need a switch with poe budget of 408W if i needed  to turn in all ports APS 225 without any restrictions  i mean 5ghz and 2.4ghz radios operating without restrictions
Did i undesrtand it correctly? or did i misunderstand?
Cheers
Carlos
Alternetworks Corp
Re: AP 225 power usage
NightShade1 wrote:
Hello
Does this mean that the AP 225 will use all his streams 3x3 in 2.4ghz and 5ghz  17 W?  i mean the AP wont go in conservative mode in which  you will see the PWR led going orage which means that its using1×3:1SS mode  ?  YES
Did i undesrtand it correctly? or did i misunderstand? YES
Cheers
Carlos
Nice Collin thats good to know that i only need a switch of 400W to power up at least 23 APS 225 without any restrictions! :)
I  just wanted to be sure because if i needed 30W for each AP i would need then 690W and that swtich cost a lot more...
This will help a lot
Thank you man!!!! for being always here :)
Cheers
Carlos
Alternetworks Corp
