Frequent Contributor I
AP-225 with LAG.LACP and Fast Failover
So with the AP-225 you configure LACP and then set the LMS-IP in the AP System profile, then you set the GRE-Stripping IP,  So when you provision the AP-225 it load balances the GRE tunnels.
Does NAybody know what happens with this configuration related to Fast Failover?
Can Fast Failover be used with this set up?
