Frequent Contributor I
AP-270 Series Dual radio in same frequency ?
Could you confirm me that the AP-270 can support concurrent operation of both radios  in the same frequency band (2.4 GHz and 5
GHz).
According to the matrix (http://www.arubanetworks.com/pdf/products/MAT_AP.pdf) it's OK
Regards
Yann
MVP
Re: AP-270 Series Dual radio in same frequency ?
While it is a dual-radio AP, you cannot put both radios in the 2.4 or 5Ghz band, one radio will be in 2.4Ghz and the other in 5Ghz only.
Jerrod Howard
Sr. Techical Marketing Engineer
Confirmed. AP-275 is very similar to the AP-225 from a RF perspective. There are two radios which operate in 2.4GHz and the other in the 5Ghz band.
Ok thank you for your answer.
I think they need to modify the Access Point Matrix...
regards
Yann
MVP
[ Edited ]
I will suggest they update the doc.
Edit: Done, change requested
Jerrod Howard
