AP-274 point to point bridge
There are 2 access points AP-274 with external antennas ANTENNA KIT ANT-2X2-5314.
2 questions:
1. Can I do this as in the picture?
At the moment, buy mst200 there is no possibility.
2. Did not find the information on the range of the antenna. Can I use them for the 500 metro distance?
Re: AP-274 point to point bridge
The MST200 has a built in antenna with 13dBi of gain. The ANT-2x2-5314 is similar, with 14dBi but with slight different beamwidths.
The ANT-2x2-5314 only provides two antenna leads, while the AP274 has three (per band). If one of the antenna connectors is left unused, it should be connected to a terminator.
Distance should be fine, but for any outdoor deployment the installation options and physical environment play a significant role.
Charlie Clemmer
Aruba Customer Engineering
I would like to ask the first question again.
Is it possible to bridge the ap207 as a point-to-point and merge two networks in different buildings, as is done with the help of mst200.
The AP207 also supports mesh and can be used for point-to-point connectivity. The AP207/AP274 is a different architecture than the MST200, and does not interoperate between the two. The network needs to either be ArubaOS based (AP207/AP274) or MeshOS (MST200), but not a mix of both on the same link.
Charlie Clemmer
Note the AP-207 is not the fastest or highest performing AP so your mileage may vary on the range and rate you get.
Sory, sory
I have a typo in the name. The correct name is ap274.
As I understand it, I can organize a mesh link and connect 2 remote Ethernet networks with ap274?
In the documentation for ArubaOS found such solutions. This is acceptable for ap274?
There is also a 7008 Mobility Controller available.
I am new to these solutions, but I want to work with this equipment.
Thanks for answers.
That is correct, the AP274 does support mesh and can therefore support point-to-point and/or point-to-multipoint options.
Charlie Clemmer
