Not right now, no. The issue with outdoor APs having diplexed antenna connectors like the indoor Aps is that it limits you in what antennas you can deploy. For mesh, we often need a directional 5Ghz antennas and omni-directional 2.4Ghz antennas, and we couldn't do that with a diplexed solution. For 95% of the customer out there that want a directional client access solution, the 277 is a perfect fit. Most antennas over 7-8dBi don't work real well for client access, as using a 14dBi directional 2.4Ghz antenna won't really buy you much more distance than a 277 will, as most clients have a 400-600m limitation at the PHY level anyway. You might see good SNR at 1/5km with a client, but the client won't be able to talk back to the AP and the distance is too far anyway and the packets time out over the air.
If you just need the narrow pattern and don't care about distance, the 2314 is a fine solution (albeit that antenna is pretty large, as are any 2.4Ghz 10dBi+ antennas). For a dual band narrow-pattern solution (like what we use in many VHD/LPV solutions), the 5314 and 2314 work fine.
you can also use the ANT-2x2-2314/5314 on the AP-274 without issue, you just want to put a 50Ohm terminator on the unused 3rd chain connector.
