Trusted Contributor I
AP-275 Antenna Pattern
For some reason the pattern plots are missing from the AP-275 data sheet.  Does anyone happen to know where I can find the pattern plots?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: AP-275 Antenna Pattern
Here you go
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
RLB
Contributor I
Seth...have the Antenna patterns for the new AP277 made publically available?  Thanks, Randy
Well, as its 80º H x 80º V it should be something in between the AP-ANT-35 and 38, (Antenna Matrix) but it would be helpfull to have the actual pattern.
Kind regards
Jan Vidar Rognsvag
RLB
Contributor I
Here are the AP277 antenna patterns that I got from my Aruba SEs...Randy
Thanks, I flipped the vertical patterns and combined them for easier overview. Maybe you could upload the original version if you ever receive it.
Contributor II
Can someone confirm, in regards these pattern diagrams, whether the dB value shown refers to the inner or outer ring (the values are shown between two rings).  I have added these patterns within my AirMagnet planner and I think it possible that I'm 5 dB (!) out, given the coverage shown.
The dBi value is placed on the outside of the related circle as the gain of the AP-277 is 6,5 dBi for both bands.
Contributor II
Of course - that makes perfect sense, now you point it out (and I think about it!)
Fortunately my AirMagnet plots are good then...   :)
Thanks very much!
