Frequent Contributor I
AP-275 Mesh Point Topology Parameters "None found"
I have an AP-275 configured as a Mesh Point in a mesh cluster.  In the 7205 controller, under Monitoring - CONTROLLER - Mesh Nodes - Topology, it is listed under the Mesh Portal in its AP Group, but when I click on it, the Parameters Value that show up for all the other nodes do not show up at all.  Instead it shows "None found."
I have reprovissioned this AP a few times and the Portal is showing all the right Parameters Values.
What am I missing?  Do I have a bad AP?
Re: AP-275 Mesh Point Topology Parameters "None found"
You might have a bug.  Please open a TAC case and let us know the result.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Found the bug.  We had an "&" in the name of the AP.   I took that out and the Parameters and Values came right up.
Thanks.
