Occasional Contributor I
AP-275 Not powering up
One of our right AP-275 units is not powering up at all.  I've tried it on two separate PoE switches but get nothing.  I've also tried resetting it with the reset button.  I was getting ready to open it up and troubleshoot and repair it myself.  Anybody with experience working on one of these ap's have any idea what it might be or what I need to look for?
Re: AP-275 Not powering up
The AP-275 requires 802.3at power to work. http://www.arubanetworks.com/assets/ds/DS_AP270Series.pdf
 What kind of switch is this?
It and the other seven AP-275's are all on an HP2910al-48g PoE switch.
They've all been running on that same switch for over a year. I tried
plugging it into other ports on the same switch and also to my HP 8200 PoE
backbone.
Wm. Wayne DuBose
IT Specialist | Angelina College |
936-633-5330 | wdubose@angelina.edu |
It seems like there could be a problem with that specific AP.  I would contact TAC.
