AP-275 and AP-315 Rebooting - ???
  • 1.  AP-275 and AP-315 Rebooting - ???
    Posted May 07, 2018 09:43 AM
    I have 13 AP-275s and 12 AP-315s working off a 7205 controller that seem to be rebooting at times.
    Running #show ap debug system-status ap-name NAME for the 315s is giving me "Reboot Informatio - AP rebooted caused by cold HW reset(power loss)".
    But running the same command for the AP-275s is returning "(none found)" under "Reboot Information".
    I am trying to determine for sure that these APs are loosing power, but how do I find that out for the 275s?
    Jason...
  • 2.  RE: AP-275 and AP-315 Rebooting - ???
    Posted May 16, 2018 04:15 AM
    Hi Jason,
    Did you had the chance to cross check the power budget on the switch or any corresponding logs ?
    Does the switch allows you to set POE at high priority for a switch port ?
  • 3.  RE: AP-275 and AP-315 Rebooting - ???
    Posted May 16, 2018 07:28 AM
    We did find out the the ethernet switches the APs are connected to are rebooting, too, due to loss of power.  So, got the techs checking into that.
    Also, I found on a couple mesh point they look like they are loosing connection with their portals.  I turned off ARM for those portals and the points are staying up now.
  • 4.  RE: AP-275 and AP-315 Rebooting - ???
    Posted May 21, 2018 12:16 PM
    Did you try to the commadn "sh datapath tunnel table"
  • 5.  RE: AP-275 and AP-315 Rebooting - ???
    Posted May 21, 2018 12:22 PM
    No, have not run that command.  How do I read the results?
  • 6.  RE: AP-275 and AP-315 Rebooting - ???
    Posted May 21, 2018 01:16 PM
    Look in the Rebootstrap Information to find the error about the device.  NOrmally it will give some indication about the Power loss.  The command I gave earlier was for another thread.  my mistake.
