Guest Blogger
AP-275 as Wired Bridge
I am trying to make an AP-275, configured as a mesh point, act as a bridge for wired devices behind it.
Right now we are using third-party radios (Engenius ENH200) to accomplish this.
They have to authenticate with ClearPass using PSK/MacAuth in order to get into the correct role in the controller.
We are configuring the Engenius as a Client Bridge and connect a switch to the LAN port and then connect the end devices to the switch.
We then enter the mac address of the Engenius as a Known Endpoint in ClearPass. We then configure the Engenius to use the PSK.
After that, the Engenius forms a link with a 275 as a client, gets dumped into the correct role, and then bridges the traffic for the devices behind it.
If I have an AP-275 out there as a Mesh Point, how would I accomplish this using it instead of a third-party radio?
I have E1 on the AP configured in the correct Bridge Role. I have the Wired AP enabled and in "bridge" mode. I'm not sure of what else I have to do though. Using the other radios was pretty straight-forward because it just showed up as a client. Is there a way to make the 275 just connect as a client and skip the meshing altogether?
Re: AP-275 as Wired Bridge
The 11ac access points do not currently support mesh. It is coming later this year as a software update.
Tim Cappalli | Aruba Security
Guest Blogger
I am using a beta version that allows them to. I have many already functioning as mesh APs.
If you are using a controller based AP-275 (Campus AP), it cannot be configured as a standalone wireless client. We can configure it only as a mesh.
If you are using an instant version - IAP-275, this is possible. But there are certain limitations such as "when the Wi-Fi uplink is in use, the client IP is assigned by the internal DHCP server."
Below are the reference links to configure an Instant AP as a wireless client.
- https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-to-configure-an-IAP-as-a-Wifi-client-though-both-CLI-and-GUI
- http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/Uplink%20Configuration.htm (See Wi-Fi Uplink section).
Rajaguru Vincent
Rajaguru Vincent
CWNA | CWSP | CWAP | CWDP | ACMP
Guest Blogger
Thanks for the reply. I am using a Campus AP.
Is it possible to bridge the wired clients in a similar way using the 275 as a Mesh Point?
Mesh link configuration steps for bridging is given in the below kb article. See if this helps you.
- https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-807
Rajaguru Vincent
Rajaguru Vincent
