Hi ,
could any one please told me what is the max point to point distance link that we can get with AP 277 and 367 .
i can't found any documentation about it.
what is the use cas of AP 277 and AP 367 is it the access or the ptp link
regards
The AP-277 is ideal for short PtP links under 1km. While links can be built out at longer distances, care should be taken to survey surrounding RF interference. The 277 has an 80deg x 80deg integrated directional 6.5dBi antenna, as such, it can pick up a fair amount of RF interference in dense areas.
hi Seth ,
what about AP 367
You should get similar ballpark performance. 1km or less is still the target.
Concur with Seth, and would add that the 277/367, while it can do 1km in clean air fairly easily, if this is meant to be deployed in a high noise/high interference environment, you should use the 274+5314 to maximize isolation and gain.
Hi, the 5314 is a 2x2 antenna but the 274 is a 3x3 AP.
Does aruba recommend mixing MIMO like this or having one antenna connector unpatched?
There is an ANT-4x4-5314 that can be used witht the 274. You can also use the 2x2 version and put a 50-ohm terminator on the ANT2 chain.
Jerrod, why wouldn't you recommend
ANT-3x3-5712 for this application?
