AP 277 and Mechanical Tilt
[ Edited ]
I'm trying to ascertain whether the AP 277 integrated antennas have any built in electrical tilt . Trying to ensure i don't over-tilt if tilt is already built into the antennas.
MVP
Re: AP 277 and Mechanical Tilt
[ Edited ]
it has neither mechanical or electrical tilt.
Koen (ACMX #351 | ACDX #547 | ACCP)
Thanks very much, appreciated!
Sky
