Frequent Contributor I
AP 277 not broadcasting SSID
Hi All,
Would like to check if i am missing out anything, have loaded AOS8 on a 7005, AP used is AP277.
Have sufficient AP licenses, WLAN configured with AP group assigned with a SSID.
Am able to see the assess point online, but the SSID set is not seen.
Re: AP 277 not broadcasting SSID
How are you powering that access point?  The AP-277 requires high powered (802.3at) POE.  Type show ap tech-support ap-name <name of ap> | begin "Power Status"  on the commandline of the controller.  You would typically need a power injector or if this is poe, you would need to have LLDP enabled on the switchport for the AP to negotiate higher power.
http://www.arubanetworks.com/assets/ds/DS_AP270Series.pdf
Also type "show ap database" to see if the access point has flags.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
hi joesph,
i believe the required power of 277 will require 27 watts thereabouts, am powering up using a brocade switch on POE+ , have assigned 30 W of power.
Please type
That will show you what power the access point thinks it is getting.
this will churn out a whole list of information instead of a single liner? as am not able to identify the amount of power its getting.
Power Status
ItemValue
Power Supply: POE-AT
LLDP Power: 0.0W
Current Operational State: No restrictions
Then you need to type "show ap database" to see if your AP has any flags.
c8:b5:ad:c3:4b:14  RWH  277      192.168.50.21  Up 8m:33s  IL     192.168.50.18  0.0.0.0
It states unlicensed, but none of our eval licenses have been consumed yet.
Type "show keys" to see the number of licenses you have.
Licensed Features
Feature                                             Status
Access Points                                       0
RF Protect                                          0
VPN Server Module                                   4096
xSec Module                                         0
Next Generation Policy Enforcement Firewall Module  0
Advanced Cryptography                               0
WebCC                                               0
Beta AP                                             0
MM-VA                                               0
MC-VA-RW                                            0
MC-VA-EG                                            0
MC-VA-IL                                            0
MC-VA-JP                                            0
MC-VA-US                                            0
VIA                                                 0
RF Protect                                          ENABLED
Policy Enforcement Firewall                         ENABLED
VPN Server                                          ENABLED
xSec Module                                         DISABLED
Policy Enforcement Firewall for VPN users           DISABLED
Advanced Cryptography                               DISABLED
Maritime Regulatory Domain                          DISABLED
X86 VM SKU Activate                                 DISABLED
WebCC                                               DISABLED
Beta AP                                             DISABLED
MM-VA                                               DISABLED
MC-VA-RW                                            DISABLED
MC-VA-EG                                            DISABLED
MC-VA-IL                                            DISABLED
MC-VA-JP                                            DISABLED
MC-VA-US                                            DISABLED
VIA                                                 ENABLED
The eval licenses were input into the mobility controller, but upon retrieving of the command apparantly there were no licenses?
