AP-303H Wall mount keystone jack ports
Does anyone know what keystone jacks will fit in the AP-303H-MNTW Wall mount kit sockets?
We use Molex cat6A jacks but they don't fit into the socket available in the wall mount. Is there a different, particular jack that will fit?
Aruba
Re: AP-303H Wall mount keystone jack ports
The openings in the mount are supposed to fit any keystone insert, but there is indeed significant variation. We have tested this with a variety of keystone inserts, but still a limited sample size..
Could you share the specific molex part number and some pics to show the issue?
/Onno
This is the jack we use, it is only about 1mm too big in each dimension.
http://www.molexces.com/product/ksj-00062-02-powercat-6a-shielded-jack-8w-white-shutter/
Aruba
Hmm, not sure where these are used, but I don't think this one is considered a "keystone" jack. Perhaps Molex has their own standard?
I can find multiple keystone compatible ones online.
/Onno
