AP-314 and ANT-48 Antenna Connections
Hi Community,
We are deploying some AP-314 with the antenna AP-ANT-48. I wonder that the below connection matches between antenna and ap are correct?
Antenna Port                        AP Port
Port 1+45°                            ANT 0
Port 2-45°                             ANT 1
Port 3+45°                            ANT 2
Port 4-45°                             ANT 3
Re: AP-314 and ANT-48 Antenna Connections
That's a good combo.
Jerrod Howard
