AP-315 - 2930M 24 POE+ System LED Orange
  • 1.  AP-315 - 2930M 24 POE+ System LED Orange
    Posted Jan 10, 2018 05:45 AM
    i have a fresh insatlled 2930m stack (740W POE+) each switch and 1 AP-315. The AP is working fine but System LED is orange, which i low power operation as far as i know.
    The switch is showing:
    sh power-over-ethernet 2/20
     Status and Configuration Information for port 2/20
      Power Enable      : Yes                   PoE Port Status    : Delivering
      PLC Class/Type    : 4/2                   Priority Config    : low
      DLC Class/Type    : 0/-                   Pre-std Detect     : off
      Alloc By Config   : usage                 Configured Type    :
      Alloc By Actual   : usage                 PoE Value Config   : n/a
      PoE Counter Information
      Over Current Cnt  : 0                     MPS Absent Cnt     : 4
      Power Denied Cnt  : 0                     Short Cnt          : 0
      LLDP Information
      PSE Allocated Power Value : 6.5 W         PSE TLV Configured : dot3, MED
      PD Requested Power Value  : 0.0 W         PSE TLV Sent Type  : dot3
      MED LLDP Detect           : Disabled      PD TLV Sent Type   : n/a
      Power Information
      PSE Voltage       : 56.2 V                PSE Reserved Power : 6.6 W
      PD Amperage Draw  : 116 mA                PD Power Draw      : 6.6 W
     Refer to command's help option for field definitions
    What is needet to be configured to get POE+ working?
  • 2.  RE: AP-315 - 2930M 24 POE+ System LED Orange
    Posted Jan 10, 2018 08:58 AM
    firmware update of the switches to 16.04.0011  and now the AP got the power he wants to have
