Guest Blogger
AP-315 Mount JX961A AP-MNT-CM1
Does anyone know if the JX961A AP-MNT-CM1 is designed for use on a 15/16” flat tbar recessed ceiling tile grid with the tiles that hang below the grid structure?  I know in the past Aruba has not had one for this particular case so I'm trying to understand if this one would work. This particular SKU is new to me and the install guide is a bit vague since it’s a drawing and not a real life example.
Does anyone have a real world deployment picture for this mount?
Thanks!
-Scott
Scott L - ACCP, ACMP, CWNE #253
Re: AP-315 Mount JX961A AP-MNT-CM1
Can you provide a link to the Armstrong or whatever brand model of the tile and rail system you are referring to, and I can compare schematic drawings? Generally they can be made to work with some trimming on the tiles. Thanks
Jerrod Howard
Guest Blogger
Just the man I was looking for Jerrod.
Here's one example of the type I'm talking about.  We were trying to not have to trim the tiles any, or have to leave them kicked up at the AP location as the included AP-220-MNT-C1 requires.
http://www.armstrong.com/residential-ceilings/ceiling/brighton-266-panel/50-44722
I think I have a 15/16" rail somewhere, I will see about trying to get the C1 clip on a rail and take some pictures. I don't have the tiles though. That being said, the C1 supports (or SHOULD support) the 15/16 rail.
Jerrod Howard
Guest Blogger
The CM1 is the one I need a picture of.  The C1 is what comes in the AP box so I already know that one :)
Yea, late night fat finger. I do NOT have a flat rail to snap it on to, but these pictures should give you all you need. Pretty sure this will not work on a 9/16" rail (though when you read the spec on the 9/16" rail, they are not designed to hang weights on them heh).
Jerrod Howard
Guest Blogger
These are perfect for what I needed Jerrod.  I appreciate it greatly!
-Scott
