AP 325 vs AP 324 for wallmount
Hi guys,
I have to upgrade our AP 125s to new AP models. I am considering AP 325 or AP 324 since these support wave 2.
In my building we only have option for wall mounting these APs. Shoudl I consider AP 324 or AP 325 as I have heard that the ANtenna Pattern for 325 is for celing mount while AP 324 can better support wallmount?
ANy suggestions.
Re: AP 325 vs AP 324 for wallmount
The AP325 does not have any external antennas and should be mounted on the ceiling.  To get the same antenna pattern as the AP325 while mounting on the wall, you would need to get the AP324 and 4 ap-ant-1w antennas.  Please see the buying guide here:  http://www.arubanetworks.com/assets/og/OG_AP-320Series.pdf for more details.
