Occasional Contributor I
AP-335 not showing in 3400 Controller GUI
I have a 3400 controller running what I believe to be the latest supported release of Aruba OS: 6.4.4.8.
I just bought a AP-335 and its showing as Aruba OS 6.5.0.0 in the serial console.
Unfortunately, although it gets an IP address, the Ap never shows up in the controller GUI.
I thought I would need to upgrade the controller but it shows in the 6.5 release notes that 6.4.4.8 is the last supported release for my controller is 6.4.4.x.
is this a common problem and easy to fix?
Anyone have any ideas whats wrong here?
Thanks in advance.
JB
Re: AP-335 not showing in 3400 Controller GUI
You need AOS 6.5 and a controller that supports 6.5.
Tim Cappalli | Aruba Security
Thanks for the quick answer.
MMhhh thats not so good.
Didnt want to be buying a new controller to use this AP.
Cant seem to find the IAP-335 for sale anywhere either.
Any idea if Aruba/HPE is planning on supporting 6.5 on this controller?
JB
AOS 6.4.4 is the last version to be supported on the 3000 series.
http://www.arubanetworks.com/support-services/end-of-life/#MobilityControllers
Jerrod Howard
I finally got my new controller.
Its the 7010 and I loaded 6.5.0.0 on there:
Aruba Networks
ArubaOS Version 6.5.0.0 (build 55392 / label #55392)
Built by p4build@chios on 2016-06-10 at 23:28:45 PDT (gcc version 4.4.5)
(c) Copyright 2015 Hewlett Packard Enterprise Development LP.
When it boots up and I log into the console I get an error that doesnt make any sense to me since it doenst have any AP connected yet:
Ancillary image stored on flash is not for this release
* WARNING: An additional image upgrade is required to complete the *
* installation of the AP and WebUI files. Please upgrade the boot *
* partition again and reload the controller. *
Is this a common issue with 6.5.0.0 on a 7010 controller?
thanks in advance,
JB
