Occasional Contributor I
AP-365 Instant Mesh
Hello all,
Would would be the maximum distance for an AP-365 mesh link. The AP will be in Instant mode. The mesh I need to create is about 50 meters between the AP's with a clear line of sight. If 50 meters is too far we may be able to move the AP's so the distance is 43 meters.
Re: AP-365 Instant Mesh
it will easily do 50m, so long as there is clear line of sight and not any major interference issues.
Jerrod Howard
