@mfahey wrote:
Thanks.
But how do I do Mesh then with Aruba. You got rid of your mesh product line. I have two AP-375 at a outdoor stadium. I have a few cameras I want to mount on poles and I need a mesh ap. I am not going to spend the money for more AP-375 to do MESH simply to connect one device.
Any suggestions?
Mesh is supported on both our controller and Instant product solutions.
Any of our current outdoor APs should work for your use-case of connecting wired cameras back via the wireless network.
If it's a single camera at a location, a 3rd party Wifi bridge could also be used to connect the wired camera to the wireless SSID. The reason the Ubiquiti model you mentioned is not an option is because it uses proprietary mechanisms unique to Ubiquiti, it does not use standard 802.11 Wifi (according to the datasheet I found).
