Frequent Contributor II
AP-61 and Old AOS
My customer has an old project saying that ARUBA AP-61 can not discover the controller if layer 3 connection existed between them. I am not working on now, I just want to know if there was in issue in AP-61 or with old versions in discovering the controller (especially using DHCP Options) ?
Re: AP-61 and Old AOS
Can you let us know the code  the controller is running.
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
I will check and get back to you.
