Frequent Contributor II
AP 65/70 firmware upgrade/downgrade
Have ap65/70's that will be connected to new controller, so will be upgraded firmware wise.. ifI need to roll back to older controller will they downgrade ?
Also have a need to change controller master/local IP's.  AP's have master/backup LMS ips hard coded so will have new AP profiles pointing to new master/local, any issues with this ? Currently take IP addresses from controllers using ADP.
Valued Contributor II
Re: AP 65/70 firmware upgrade/downgrade
Hi Friend,
My advice is, purge the AP and configure DHCP with option 43 and 60 to provide master IP as required and then provision the APs with LMS and Backup LMS as desired.
Please feel free for any further help on
Venu Puduchery,
