Occasional Contributor I
AP-93 unable to work on IAP mode
We have recently bought a AP-93 Access Point and upgraded it with ArubaInstant_Orion_6.1.3.4-3.1.0.0_35320 firmware.
The upgrade was successful but now unable to configure it.
admin/admin doesn't work and the console show this message: "turn off mobility"
Thanks for your help
Re: AP-93 unable to work on IAP mode
Did you try the reset button?
Valued Contributor I
Please clarify if you purchased an AP-93 or an IAP-93.
A regular AP-93 cannot be upgraded to become an IAP-93.
If this is an IAP-93 can you explain your upgrade process?
Oh OK! We have purchased an AP-93...
Thanks for your reply
Hi Same error am using IAP-105... any workaround? its not broadcasting default ssid recolor in both 2.4 & 5 led
ip_time_handler: Got ip and packets on bond0 Started master election 6-0
process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
asap_send_elected_master: sent successfully
i am a potential master now
turn off mobility
have you tried to use a cable?
set IP adres with console cable and connect with a ethernet cable to go to gui
