Frequent Contributor II
AP-93H and 5GHz Mode
Does anyone know how to switch the band on the AP-93H from 2.4GHz to 5GHz?
Do you do it by AP group or by the AP itself? I can't seem to find the setting.
Thanks.
Re: AP-93H and 5GHz Mode
You can do it in AP system profile. Select RF-Band as A instead of G (which is default). This way all your single radio APs will by default come up with 5GHz instead of 2.4.
BTW, AP system profile does under AP-group. So find out which AP-groups are you using and what AP system profiles are being used.
Thanks for the reply. I ended up creating a new AP group and copying our main AP system profile. We use a lot of 93h units in our dorms but we don't want those on 5GHz. However, we have a few 93h units in offices that we do want on 5GHz.
