AP 93H not discovered
I have a problem with AP 93H not beeing discovered by the controller..
I am using controller 3600 not sure about the OS version, connecting to the AP using console shows that it is getting an IP address but still not showing on the controller. The controller is working fine as other APs are beeing discovered normally without any issues so I am suspecting that the AP is faulty.
The following is the last couple of lines from the AP console, not if it is healpful attached aslo test file including more from the console
Getting an IP address...
ag7240_ring_alloc Allocated 640 at 0x82d66800
ag7240_ring_alloc Allocated 4032 at 0x82dad000
Virian MDC CFG Value ==> 4
Setting PHY...
ATHRSF1_PHY: Port 0, Neg Success
ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
ADDRCONF(NETDEV_UP): bond0: link is not ready
Re: AP 93H not discovered
The AP93H has a minimum code level of 6.1.3.0 http://www.arubanetworks.com/pdf/products/DS_AP93H.pdf
You only have 6.1.2.5.  You need to upgrade your controller code.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Will upgrade the os and tryb gain, thank you.
