AP 93H problem
ARUBA AP 93H ,when I reset AP display this
APBoot (build 32721)
Built: 2012-03-08 at 11:34:00
Model: AP-9x
CPU:   AR7242 revision: 1
Clock: 390 MHz, DDR rate: 390 MHz, Bus clock: 195 MHz
DRAM:  64 MB
POST1: mem 0 (Mismatch at a0200d34: Expected f5755861 got afbe0048) FAILED!
Copy:  done
Flash: 16 MB
PCI:   scanning bus 0 ...
       dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
       00  00  168c  002a 00002   01 10000004 00000000 00000000 00000000
Net:   eth0
Radio: ar9280#0
Re: AP 93H problem
I think maybe the mem is faild ,can i do anything,to make it ok
Re: AP 93H problem
So the AP is not booting up completely?
If the AP does not boot completely then the only thing you can do is trying to clear os
if clear os does not sove it and you keep getting that error then there is not too much you can do... just do a RMA...
When an ap does not boot
I actually just do clear os and if that does not fix it i open a case for a RMA.   Also put where is it hanging... and Aruba support always accept my RMAs rquests
Alternetworks Corp
Re: AP 93H problem
thank you
I clear the os ,but AP also cant boot.
 Image is signed; verifying checksum... failed! 0xa6f0325a
can i refresh the os
Re: AP 93H problem
For issue like this, please open a TAC case.
Thank you
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Re: AP 93H problem
If image is failing and you already did clear os just open a support case and ask for a RMA
Told them i already did clear os but im still getting that
They will grant it... becasue there isnt too much you can do with the AP, remenber the ap is a thin ap  is not complicated it works or it does not work... haha in this case is not working so you need a replacement... and also there arent too manyt things you can do
Alternetworks Corp
