Contributor I
AP-93H wired and ethsw packet errors
Hello.
We have a dorm full of AP-93Hs and I'm busy trying to troubleshoot an issue where a Mac user complains he loses connectivity several times a day on the wired AP-93H ports.
While poking around I noticed the "Interface Information" section from "show ap debug system-status" which contains:
Inter-|   Receive                                                |  Transmit
 face |bytes    packets errs drop fifo frame compressed multicast|bytes    packets errs drop fifo colls carrier compressed reset
    lo:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
  sit0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
 ethsw:117313175  203346 63134  633    0 63134          0      1365 113019365  134393    0    0    0     0       0          0     0
  eth0:102262743  145823    0    0    0     0          0         0 14431771   58863    0    0    0     0       0          0     0
  eth1:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
  eth2:10955660   56890    0    0    0     0          0         0 98048491   75524    0    0    0     0       0          0     0
  eth3:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
  eth4:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
 bond0:102262743  145823    0    0    0     0          0         0 14431771   58863    0    0    0     0       0          0     0
   ap0:       0       0    0    0    0     0          0         0    23137     229    0    0    0     0       0          0     0
   am0:       0       0    0    0    0     0          0         0  1631079   13308    0    0    0     0       0          0     0
  gre0:       0    1224    0    0    0     0          0         0        0   58428    0    0    0     0       0          0     0
apsos0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
   br0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0     0
 wifi0:  341537    6002    0 1334    0  3107          0         0   608636    2346  609    0    0     0       0          0     0
aruba000:       0       0    0    0    0     0          0         0   218880     901    0    0    0     0       0          0     0
aruba001:       0       0    0    0    0     0          0         0     8202      25    0    0    0     0       0          0     0
eth0 and eth2 show no errors but ethsw shows quite a few. What is ethsw and what do these errors mean? Thanks.
