Occasional Contributor I
AP ANT -17 antenna extenders?
I will be deploying next week for a wireless install and I need some help with installing an AP ANT 17 outside the building.
I am planning to mount the AP 224 inside the building and mount the ANT 17 outside the building but I think the cable antennas will be too short.
Do you carry antenna extenders? Do you have any suggestions? I really don't want to mount the AP outside and deal with ligthning arrestors, grounding, and weatherproof box.
I can see the Antennas but I don't see any APs in the picture. How did they run the cables to the APs and are the APs mounted on top of the roof?
Thank you.
Re: AP ANT -17 antenna extenders?
If your antennas are mounted outside, you should really have the lightening arrestors. You should consider something like the AP-ANT-92 which has N type connectors. You can then get pigtail cables of various lengths to go from the lightening arrestor to the AP.
ACCP, ACCX #817, ACMP, ACMX #294
do you have the model numbers and part numbers for arrestors and pigtail cables?
Anyone know the part number for those antenna mounts? They look like some kind of swivel.
Aruba
The mount kit for AP-ANT-17 is AP-ANT-MNT-1.
Note that both the antenna and the mount are end-of-sale for some time (2015).
The replacement antenna is AP-ANT-25A (2x2), AP-ANT-35A (3x3) or AP-ANT-45 (4x4). The equivalent mounts are AP-ANT-MNT-3 for the first two antennas and AP-ANT-MNT-5 for the 4x4 one.
/Onno
will the new mounts work with the 17? or are the holes different?
Network Support Assistant
California State University, Monterey Bay
The mounts for the new antennas are not compatible with the old antennas.
Jerrod Howard
thanks!
