I'm doing an outdoor plaza installation and the buldings range from 3 stories to 10. What kind of range should I expect from the AP-ANT-17 antenna? We'll use either 135s or 175s depending on indoor/outdoor mount location.
I'm getting feedback of maximum 20 feet high, but that doesn't seem legit.
Antennas will be mounted on building parapets aimed down without obstruction to outdoor plaza.
