Frequent Contributor II
AP-ANT-1B & AP-ANT-1F
i will get AP-134 , when to use AP-ANT-1B & when to use AP-ANT-1F ?
Re: AP-ANT-1B & AP-ANT-1F
The only difference between the two is that the AP-ANT-1F has a cellular interference filter.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Aruba
True, but as a result the gain of the -1F antenna is a bit lower. For typical deployments (especially with the AP-13x which is less sensitive to the issue than Ap-9x or AP-10x) I would recommend using -1B. If the expected interference from cellular systems is quite high (AP's positioned within a coupld of m of cellular transmitters/antennas), -1F would be the better choice.
/Onno
/Onno
Super Contributor II
Hi Joseph,
Can you please explain more on it
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
syedmuradali wrote:
Hi Joseph,
AP-ANT-1F has a cellular interference filter and the AP-ANT-1B does not.
Aruba
Filter specs are included in the -1F datasheet
/Onno
