AP-ANT-38: Cross or Co Polarization & Gain
Should the AP-ANT-38 with the IAP-224 be setup for cross or co-polarization? I can't find anything in the documentation.
 Additionally, what should the antenna gain be set to?
Re: AP-ANT-38: Cross or Co Polarization & Gain
Gain should be set to 7.5dBi. The antenna has 3 elements integrated in to the unit itself, and is already polarized (+45 / V / -45)
Jerrod Howard
Thanks! A couple of questions still.
I'm on firmware 6.5.3.1. I've set the gain with the CLI but it only shows in the CLI, not the GUI. When setting in the GUI, it continues to show as zero:
I have tried in multiple browsers.
What I was trying to ask with the polarization questions is what to select here:
Thanks!
Ah, that's new, chose cross polarization. Not sure about the zero for gain, but the CLI is likley more reputable. I will see if anyone on my team has a 6.5.3.1 IAP with external connectors and if they see the same behavior.
Jerrod Howard
Frequent Contributor I
Is AP-ANT-35A also cross polarization ?
Cant find anything in the documentation :(
Also my webgui shows 0 all the time regardsless of reboot or not. And my cli shows the value I input, in this case 5.0
/Daniel
ACMP | ACCP | HP ATP - FlexNetwork Solutions
