Regular Contributor II
AP-ANT-40 installation guide?
Hi Forum,
Has anyone seen an installation guide for the new AP-ANT-40? I can't find one on the support site.
Re: AP-ANT-40 installation guide?
Are you looking for the Datasheet or Installation guide?
You can find the Datasheet @ http://www.arubanetworks.com/assets/ds/DS_AP-ANT-40.pdf
Rajaguru Vincent
Rajaguru Vincent
Looking for  installation guide.
MVP
[ Edited ]
We don't have the installation guide out just yet, but the below pictures and description should be all you need until it's published.
Looking at the attached pictures below, you can see that there is a center hollow post where the pigtails come up. That post has a diameter of 1", and the threaded nut with a bezel on the bottom that is 1.5" in diameter (or 38mm wide). You would drill or cut a circular hole of that diameter in a ceiling tile or ceiling or wall element, and insert the antenna post on one side, and thread down the nut with the 1.5" bezel to sit inside the hole.
There is also a standoff bracket provided as part of the kit, should you need to surface mount the antenna and/or are no means to penetrate the wall to drill a 1.5" hole.
Below is a front and back picture of the antenna as well.
Jerrod Howard
Sr. Techical Marketing Engineer
Thanks Jerrod.
Great information.
This is a great design. I was hoping to find something like this for the AP225.
MVP
You can certainly use the ANT-40 on the AP-224, no issues there at all. You just end up with one left over pigtail that isn't used.
Jerrod Howard
