I have 4 controllers :
2 Controlers configured with VRRP with IP 10.0.0.1 VLAN 10 (Master Controllers)
2 Controllers are Locals with IPs 10.0.0.3,10.0.0.4 (VLAN 10) for communicating between masters and VLAN 20 for APs connectivity
the access points terminated on Locals with VLAN ID of 20 IP (20.0.0.1) and (20.0.0.2)
now I have configured AP Fast fail over primary LMS is (20.0.0.1) and Backup LMS (10.0.0.1)
I have Configured DHCP on Local Controllers so I can see access points.
I have aslo Enable routing between the 2 VLANs on my Core switch .
now should I enable DHCP also on VLAN 10 on te Master Controller so access points can communicate with network?
and how I can get access points automatically to the local after a fail?
